Found an F-14
BK
01-31-2004 18:51:08
My brother and I have came across an f-14. Its been sittin for a long time.It is rough. Thing is looks like everything there. The rims are rusted real bad and there is a hole rusted in the gas tank about the size of a quater. The only other thing that we seen that was real noticable was the forks that held the single front wheel have been welded several times. I know that the f-14 was a rare breed. We don't know if we want to tackle it or see if we could make some parts available for folks. Any thoughts. I hate to see the old thing just waste away. Thanks.
Fred Milner
02-01-2004 06:08:10
 Re: Found an F-14 in reply to BK, 01-31-2004 18:51:08
There are a few F-14s out there. They only made them for 2 years. The good thing about them is that the F-12 parts will fit on them. The F-14 was just an upgraded F-12. It had 2 more horsepower and turned a few more RPM. All the trans. and body parts are the same and most of the motor parts are the same. I have one F-14 and 2 good F-12s and one F-12 for parts. A lot of new parts and around for the tractors also. Get it and if you don't want to fix it at some time part it out and get all your money back and then some.
jerry
02-01-2004 04:44:16
keep ChadS away from it, or he will try to put a combine motor in it!!
old
01-31-2004 18:57:02
Well if you can get it cheap enough I'd get it, I got an F12 this summer for $300 and maybe by this time next year I'll have it running
ChadS
01-31-2004 19:14:43
 Re: Re: Found an F-14 in reply to old, 01-31-2004 18:57:02
Dad bought an old F-20 he bought cheap a few years back, Been thinking about getting running this summer. Seems like a good parade tractor. Has foot brakes, and fast road gear, (Behlen) Even the mag still works on it. Chad
The F-20 Man
01-31-2004 20:47:25
 Re: Re: Re: Found an F-14 in reply to ChadS, 01-31-2004 19:14:43
i boaught a f-20 in july last yr for $325 motor was stuck tires-shot got all new just bout got the moter put bak together planon putten head bak on tomorrow maybe if it warms up in MN
