Sleeve assemblies for DT466
Neil
01-31-2004 20:06:13
where is a good low cost source for a complete overhaul kit for DT466? Thanksin advance.
E J
02-01-2004 14:31:39
 Re: Sleeve assemblies for DT466 in reply to Neil , 01-31-2004 20:06:13
dons diesel has that kit for 795 head set &pan or full set 90extra.Cam & lifters 295
w gatewood
02-01-2004 05:28:40
go to a ih truck dealer and get the works kit has everything you need. pistons, sleves, all gaskets its the copmlete kit. and it is much cheaper than your case ih tractor delaer. and the kit from the truck dealer is the same parts that your case ih tractor dealer gets . have used these works truck kits they are just under 1000 dollars and have all the parts you need.
scotc
02-03-2004 00:31:01
 Re: Re: Sleeve assemblies for DT466 in reply to w gatewood, 02-01-2004 05:28:40
only thing that may be different is valve springs, could have more pressure to keep valves from floating at higher rpm's. Won't hurt anything though, may get ya downb the raod a little faster.
