what would you give?
Bryce Andreasen
01-31-2004 21:11:22
I have a '41 H and was thinking of selling it. It had an engine overhaul in sep 2001 with a new block. It has had trans. work, some seals repaced, new 4-5th sliding gear, Three point with good drawbar. the three point can lift the front end of the tractor easily. simple 12 volt system, painted in 2001 also. All new rubber in summer 2003. New guages, new single wire alternator. Need to work on ignition, used to start on very first spin, belived to be a new or reworked starter. year old battery. Has smaller 540 pto shaft with adapter. Want to get a Super M, MTA or Super MTA, already have 400, and want another to tractor pull with once a year at the county fair.
Charlie V
02-01-2004 14:20:11
 Re: what would you give? in reply to Bryce Andreasen (Magnum), 01-31-2004 21:11:22
I have owned a number of H's, M's WD's, I have restored an rebuilt them putting in lots of money an time an I have found out like many of the people that have done this for amny years it's the labor of love an not money. You can put well over two thousand in an H an find out you can only sell it for three quarters of what you have in it an get nothing for your labor. The big problem with H's is that there are so many of them around that every one has one or two sitting around that are running an another two for parts sitting out behind the shed or barn thus the price for just about any of them is very low an in most case's well below what you have into one once it's restored.
Kelly C
02-02-2004 03:43:10
 Re: Re: what would you give? in reply to Charlie V , 02-01-2004 14:20:11
So true. But dont hurt to try Ebay though. If its got nice paint on it never know what it will bring on there.
Van in AR
02-01-2004 04:52:59
A MTA is a Super MTA.
Nebraska Cowman
02-01-2004 03:31:44
i just gave $1000 for an H with new tires that was supposedly "overhauled" turns out the "mechanic" was lacking and I gotta pull the head and redo the valves. Wanna trade?
02-02-2004 18:24:58
 Re: Re: what would you give? in reply to Nebraska Cowman, 02-01-2004 03:31:44
sory, i want to advance HP and Torque amp
