Body filler for rust pits
Paul in Mich
02-01-2004 13:44:19
Just curious to know what some of you folks have used to fill in rust pits in sheet metal on your tractors. I'm trying to salvage a couple of original fenders. While they arent rusted through, some of the pitting is I think too deep for finish fillers. Also is there a good product that doesnt require adding a hardener?
CNKS
02-01-2004 17:38:26
 Re: Body filler for rust pits in reply to Paul in Mich, 02-01-2004 13:44:19
Remove all the rust you can, and use body filler, with hardener. Be prepared to do a lot of sanding. Some people recommend using epoxy primer first. As far as the hardener, you will get a faster drying harder finish. You can use spot putty for the pin holes that will occur in the filler. I sometimes use Eurosoft, it is a little easier to sand and has fewer pinholes. Don't understand why you don't like hardener -- it's not like the stuff you mix with paint.
Farmaller
02-01-2004 16:08:58
Best thing to use is a filler primer, it's a lot of work but it will give a much better job.
John
02-01-2004 14:19:13
We use a product called Icing. It is extremely workable, and requires a hardener. On less extreme pitting, there is another product called Thin Ice. It works reel goo for small pitts, and too uses a hardener. The fillers which require a hardener often set up quicker and allow less time before you can shape or sand. Glazing putty can be used for the final coat in some cases, but i try to use as little as possible.
CNKS
02-01-2004 17:40:09
 Re: Re: Body filler for rust pits in reply to John, 02-01-2004 14:19:13
I haven't heard of those products -- where do you buy them?
RayP(MI)
02-01-2004 18:05:57
 Re: Re: Re: Body filler for rust pits in reply to CNKS, 02-01-2004 17:40:09
Check with your local auto parts stores, or even auto department in discount stores.. Many carry some body repair kits.
RayP(MI)
02-01-2004 18:00:01
