Original colors on Farmalls, and one other questio
Phillip B. Nels
02-01-2004 16:12:48
What is the proper color of the fuel and radiator cap on a Super MTAD. The fuel replacement is black, and the radiator is silver, but?
Also, does anyone have experience with the fiber disc with the copper contact for sending spark to the gas starting stage? The item is located on the front of the intake manifold. The one I have started to turn on the rivet and would not make contact with the other two contacts to send electic current to coil, etc. I put a small stove bolt in the hole of the rivet and tightened it to keep it from rotating. Any suggestions, has anyone out there had the same problem and how did you resolve the problem?
Phil of NY
Bermuda Ken
02-01-2004 17:50:13
 Re: Original colors on Farmalls, and one other que in reply to Phillip B. Nelson, 02-01-2004 16:12:48
Both the the fuel cap and radiator cap were painted IH 2150 red at the factory.
IF you repaint the black safety gas cap, do not let the vent holes get plugged with paint!!
CNKS
02-01-2004 17:30:40
Not familiar with your diesel question. I assume you have one of the tall gas caps, in that case red. I remember the the OEM radiator cap being unpainted, most people just paint them red with the rest of the tractor.
