IHC Suitcase Weight Sizes
John Athey
02-01-2004 16:53:26
How many different size suitcase weights did IHC make? What size suitcase wights does a Farmall 504 take? and how many? How many would have been installed by the factory?
Tim Malin
02-04-2004 12:16:16
 Re: IHC Suitcase Weight Sizes in reply to John Athey, 02-01-2004 16:53:26
Actually, 100lb IH suitcase weights are 98 lbs. Otherwise, all I wanted to say was that you reminded me of a fond memory. We have a set of weights we bought with our 856 when it was brand new, and used them a couple times on our 1066, but mostly we have them in the shed for when we might need them. Used to own a MF 165, and had a massive box spreader behind it one year. It didn't really have problems pulling it, but this corner near my barn would lift it's front wheels off the ground about a foot, and then if you hit a brake to try to turn you lost all the power. Put a full bracket of IH suitcase weights on that baby and it was a new machine. I have never laughed so hard at a machine, because it is such a short tractor and little narrow front tires with all these weights. Looked okay with the spreader behind, but after unhooking the spreader it was just wrong to have all that weight on that tractor. Funny for a day, and I don't know what we would have done without them, but didn't match the tractor. Thanks for the memory.
Dave
02-03-2004 18:35:02
I use the IH flat bottom weights with the large hand hole. They are 112#s each
Red Rider
02-02-2004 20:18:24
John, IH made 6 different suit case weights.
90# with large hand hole Part # 71200201
90# with small hand hole Part # 383393R2
90# with small hand hole without angle iron hold down slot Part # 383393R1
100# with large hand hole 148347C1
75# small hand hole without angle iron hold down slot Part # 383392R1
If IH made any others I'm not aware them. Hope this helps.
Stuart
02-02-2004 08:12:03
I know of 100lbs wieghts and I think the other size is 65 or 75 lbs I can remember which. hope this helps you out
