1466 good or bad??
Chad S (from il
02-01-2004 19:26:57
i wondered if these tractors are worth buying, i dont want or need a cab, so that isnt a factor, i want somethin realiable, and if needed can be turned up some. I dont want to go crazy with it. Just make it "healthy" any info is appreciated
randy hall
02-02-2004 18:28:35
 Re: 1466 good or bad?? in reply to Chad S (from illinois), 02-01-2004 19:26:57
i bought my 1466 when it was four years old.i turned it up to 210 hp and it would pull anything that you hooked it up to, but something would break about every year. twisted off a bull pinion shaft. broke the differential housing and side gears in the differential, a couple of transmission gears and two ring and pinion sets. the first ta lasted fifteen years because we never needed to use it. ten years ago i set it back to 160 hp and haven't broke anything since.
Farmallkid
02-02-2004 09:36:56
If you go a cpuple pages ahead, i put up a post about the 1066's and got lots of replies. Not much different on the 10's and 14's i don't think. That info should help you out.
the tractor vet
02-01-2004 19:45:20
They are a good old tractor even if ya have to do the clutch and T/A , the only problem that i have seen is that if ya tweek them to much and run duals and do a lot of tuning under load they will eat the side gears out of the rearend. and since you are in the corn belt most of them that i have bought out your way are already tweek some up over 250 most around 200
02-01-2004 19:55:43
 Re: Re: 1466 good or bad?? in reply to the tractor vet, 02-01-2004 19:45:20
Yeah, I know someone who bought one new and turned it up 250 and pulled a 7 bottom plow with it, and pulled a 32 foot disc many years. he has had alot of luck with it. But i didnt know if they all were that great. Thanks for the info
dhermesc
02-02-2004 09:12:09
 Re: Re: Re: 1466 good or bad?? in reply to Chad S (from illinois), 02-01-2004 19:55:43
Good solid tractor, can be turned up easily but wouldn't want one that has been and worked hard. We have never had any specific recurring problems with rear ends on the ones we have owned (5). Did lose the rear end on one (don't recall the specifics) that was on a dozer blade. Good field tractor but a bit big and clumsy to be used as a loader tractor.
Dave Cooper
02-02-2004 19:43:29
 Re: Re: Re: Re: 1466 good or bad?? in reply to dhermesc, 02-02-2004 09:12:09
The 1466's are great old tractors. The only poor thing about them were the deluxe cabs. These cabs were monsters. If the air conditioning doesn't work, take the doors off in the summer or you'll bake!. If you can find a fender model tractor they look really awsome!
- Dave
scotc
02-03-2004 00:20:36
 Re: Re: Re: Re: Re: 1466 good or bad?? in reply to Dave Cooper, 02-02-2004 19:43:29
doesn't take much to pull cab and put on fenders.
