450 hydraulic problem
Steve
02-02-2004 19:43:36
Moving snow tonight with my 450, I lost partial use of one lever. I have a hydraulic loader with 2 way cyls. on both the bucket and the lift. The 450 has a fast hitch and factory power steering. Here's the problem: The inside hydraulic lever is hooked to the bucket dump, the center is hooked to the lift. I could dump the bucket, but it wouldn't roll back unless I would raise or lower the loader at the same time. I just had to move the center lever just a little, and it would roll back. The oil level is at full. What's wrong? Valve troubles? Thanks Guys.
RB
02-03-2004 05:46:26
 Re: 450 hydraulic problem in reply to Steve, 02-02-2004 19:43:36
What type of hose connections are you using? Worn points on IH connectors are a common problem when circuit works in one direction but not the other. Using Pioneer with IH is even worse.
Bill Evans
02-03-2004 04:48:29
Steve,
If the control linkage feels intact, you may need to get into that valve and see if it has internal problems.
But I also wonder if the problem could be in the bucket cylinder?
