806 into a 706/ narrow to wide?
riverrat
02-03-2004 09:18:52
Will a 361 diesel from an 806 drop into a 706 that had the gas engine? I'm after the reliability and "bulletproofness" that the 361 offers, rather than the 282 diesel from a 706. Also, if the 706 came with a narrow front, is changing that over to a wide front similar to the H's and M's? Not sure how the power from the steering hooks up to these two configurations. Thanks a bunch, guys!
JimB
02-03-2004 13:42:57
 Re: 806 into a 706/ narrow to wide? in reply to riverrat, 02-03-2004 09:18:52
Why not just get a 806 with a wide front? Would seem a lot simpler,unless you have all the odds and ends lying around. Just a thought.
scotc
02-03-2004 12:52:34
should be all bolt-in, maybe find a 806d w/f with a bad rearend and switch out the entire halves of the tractors?
E J
02-03-2004 09:46:53
Yes it will you will need the whole front end off the 8 plus the higher steering colume suports or you have to lenghen 706 side rails longer hood.Im going through this process but useing a dt 466 instead of a 06 motor.But the stuff will interchange
