? about putting 264 in a m
TL
02-03-2004 17:37:08
I am putting a 264 out of a junked 400 into a m.Will the 400 flywheel work or is there any thing that it needs before it will work.What about the starter? will the stock m starter work?Thankyou for your help.
Dave
02-03-2004 18:33:01
 Re: ? about putting 264 in a m in reply to TL, 02-03-2004 17:37:08
Failed to say that if you are using a belley
pump reservior for a 11 inch clutch,12 inch will not clear it.
Dave
02-03-2004 18:23:15
If you use 400 flywheel you have to use 12 inch
clutch disc and presure plate if your M doesn't
have one. Starter will work.
Bud
02-03-2004 17:44:02
Everything will work fine. Same animal.
