Super A won't start
Grail Malcom
02-03-2004 17:39:46
I have a Super A with a H4 magento. I have replaced the points, condensor and coile and it still will not crank. Does anyone have any thoughts as to what I should try next?
Jon
02-07-2004 12:06:56
 Re: Super A won't start in reply to Grail Malcom, 02-03-2004 17:39:46
If you have a hill near your house and or a truack tow it or roll it down a hill and pop start it in 4th gear. It should start then.
Grail Malcom
02-08-2004 00:57:29
 Re: Re: Super A won't start in reply to Jon, 02-07-2004 12:06:56
Thanks to everyone for their help. We got her going yesterday. After checking found the wire between points and the coil grounded.
leon
02-04-2004 07:09:52
I have an A also Mine wouldn't start , My problem was the battery was gone.(5years+) But showed that it was charging, check battery cables, starter and solnid also. Possible problems areas besides what you have already done hope this helps you
Grail Malcom
02-04-2004 03:22:28
There is gas coming to all cylinders. There is good compression. Tractor will not fire.
Tom of Minnesota
02-03-2004 19:27:47
If you replaced all the ignition parts and still don't get a consistent strong spark, check the impulse. You should be able to hear a "click," "click," "click" from the magneto as the engine turns over. The impulse system enables the magneto to generate a strong spark even when revolving slowly, which is critically important when starting. My B wouldn't start until I had the impulse repaired. Now it pops off after a few revolutions. Amazing.
Tom of Minnesota
Ben in KY
02-03-2004 18:00:19
I am assuming by it will not crank that you mean it will turn over but not fire and start ? Have you pulled a spark plug after cranking it ? Is it wet, ie getting gas to the cylinder ? Do you have spark ? Do you have compression ? If all of the above conditions are met then it is probably out of time.
