Order Farmall Cub Parts Online
How do I set gap on my cub
billy smith
02-03-2004 18:13:15
I'm 15, bought a farmall cub and now it wont start. I've done the normal things like Changed condenser, points and plugs, not sure if I got gap set right. Set it at 20 thous- at flat side of rotor arbiture. is this right or is there a specific place on the arbiture to set gap? I really dont think the coil is at fault since it ran so good before, also I blame the weather- its 25 degrees in the shed- could this have something to do with it not starting? Also after crankin the cub a little gas seeps for carb- prob from floodin the thing- any info would be great ==thanks alot
Jon
02-07-2004 12:04:41
 Re: How do I set gap on my cub in reply to billy smith, 02-03-2004 18:13:15
Hey Billy my name is Jon I am 16. I work on tractor alot I used to work for a tractor dealer working on these old tractors. I have 3 tractors of my own. But To set you gap on you tracto if it is a coil it is .20 set the point to the high side and then gap them. Let me know thought if you need and help with anytnthing if I dont know what to do my buddy that used to work on the IH assembely line would know. My e-mail adress is grahammacdonald@cox.net.
Rudi
02-03-2004 20:00:15
third party image
Billy:
Listen to George, he knows what he is talking about, and he really is a Cub Guru.
If you want to do some reading and learn more about your Cub, visit the Cub Manual server at the link below. Read the Owner's Manual and then check out the Blue Ribbon Service Manuals. Really good stuff! Also, check out the Best of H.L. Chauvin!
Peabody
02-03-2004 18:31:50
Billy,
The gap should be set at the HIGH side of the cam (what I assume your are calling the arbiture). That means on one of the four corners, not the flat side. That is probably your problem. Otherwise, I would suspect timing. But I would re-gap at "high cam" right now, and try that out. If that doesn't work, be sure to check back here. Good luck and don't give up! Glad to have you on this board!
Billy --one more ques-
02-03-2004 18:44:09
 Re: Re: How do I set gap on my cub in reply to Peabody, 02-03-2004 18:31:50
Thanks alot guys- I set my gap at the flat side of cam- thats my prob. Do I hit the starter till it just right(cam on corner) does it hurt to turn it over with the distrib. off? thanks again
old
02-03-2004 19:02:57
 Re: Re: Re: How do I set gap on my cub in reply to Billy --one more ques-, 02-03-2004 18:44:09
No it doesn't hurt but it is easyer to get it where you want by turning it over by the fan blade. unhook the battery first for safety, it can not start that way if you goofed some how
George Willer
02-03-2004 18:31:15
Billy,
The amount of the gap depends on whether you have a distributor or a magneto. In either case, the gap is measured between the point contacts themselves. It is done with the cam follower resting on the high part of the cam lobe. For a distributor, the gap should be .020", and for a magneto it should be .013". Make absolutely sure the points are CLEAN! The last thing will be to draw a piece of clean paper between the points to make sure.
Good luck getting it running. We'll try to help.
George Willer
