Gasket size for H's gas tank
Digger
02-04-2004 17:19:57
I'm putting my H back together now and I need to replace the round gaskets on the posts to mount the gas tank. The ones I have fell to pieces when I removed the tank.
Richard Clack
02-05-2004 06:08:59
 Re: Gasket size for H's gas tank in reply to Digger, 02-04-2004 17:19:57
I simply used a old tire and cut the circles out of the side wall. A little hint, It is easiest to cut the center hole for the stud before you cut the diameter of the circle. These worked fine for me. Good luck
Richard C
Fred - Kansas
02-05-2004 05:56:40
A tube liner from a truck tire would make better gaskets than an inner tube, as it is a thicker and denser material.
I think that just about any tire shop would give you a used liner just so they don't have to dispose of it.
OEM also carries them.
Fred - Kansas
Digger
02-04-2004 18:00:29
I looked on ebay and was not able to find the pads, I do have a couple of old inner tubes laying around might give that a shot thanks all
rustyfarmall
02-04-2004 17:35:06
I am pretty sure that OEM sells new ones.
Charles Park
02-05-2004 06:22:16
 Re: Re: Gasket size for H's gas tank in reply to rustyfarmall, 02-04-2004 17:35:06
Just made three this week. You can buy the ones that are already cut or the sheet of rubber and cut your own. Try JT Tractor salvage for this. They are $2.00 each.
Farmer Bob
02-04-2004 17:34:35
If you are not concerned about originality, you can cut some rounds out of an old inner-tube about the same size as the ones you removed. May want to go two or three rounds on each of the three studs as these are there to cut down vibration.
If you want original, OEM tractor parts has them and I think there is some on ebay right now as well which could also be from OEM. They are listing a lot of their stuff on ebay at the moment.
Good luck.
Nebraska Cowman
02-04-2004 17:33:54
they were nealy ¼ inch thick. I have cut them out of rubber belting or used several thickneses of inner tube. it don't need to be pretty cuz oce the tank is on they won't show
tractorboy
02-04-2004 17:31:46
there is a new set of mounting pads for H on ebay right now.
