Farmall super C or C
phillip
02-04-2004 17:39:23
How much difference is there between a super c and a c?
phillip
02-05-2004 17:24:04
 Re: Farmall super C or C in reply to phillip, 02-04-2004 17:39:23
Thank you for your help. This guy has a average shape c for $1300, I am still thinking about it.
Jim in michigan
02-05-2004 05:46:23
John is right on everything except the water pump,,, I have a C and a SC bot are original,, both have water pumps..Jim
Hugh MacKay
02-05-2004 17:45:02
 Re: Re: Farmall super C or C in reply to Jim in michigan, 02-05-2004 05:46:23
Jim: The C didn't have the water pump from factory, it has been added.
Jim in michigan
02-06-2004 07:43:28
 Re: Re: Re: Farmall super C or C in reply to Hugh MacKay, 02-05-2004 17:45:02
Ok,, I learn something new every day :) Thanks Hugh for setting me straight...JIm
BIG JOHN
02-04-2004 18:31:10
They are the same basic tractor with the Super C being the updated version. The C has a C-113 engine and the SC has a C-123 engine. The SC requires a water pump, because of the larger engine, that the C doesn't have. The radiator is slightly taller thus the grill is also taller. The SC has disc brakes and the C has band brakes. The brake and clutch peddles are straight on the C and curved on the SC. Because the radiator and grill are taller it raises the gas tank slightly.
These are about the only visable differences.
Russ
02-05-2004 13:18:00
 Re: Re: Farmall super C or C in reply to BIG JOHN, 02-04-2004 18:31:10
C Difference; I would buy a used Super C over a Farmall C just because it has cylinder liners that are well designed to meet the engine coolant and overhaul is easier because of that fact.
At the right price I would be please to have either tractor.
Hugh MacKay
02-05-2004 17:47:33
 Re: Re: Re: Farmall super C or C in reply to Russ, 02-05-2004 13:18:00
Russ: They both have sleeves.
Dave_Id
02-04-2004 17:50:33
Do a search in archives... this has been done here at least a dozen times in the last couple of years...
