glossy paint
jake
02-05-2004 06:53:17
My first restoration, I purchased delstar automotive paint 2150 for my super H. I mixed the product with hardener as recomended by the manufacture. The sheet metal shines like glass but the cast iron body is not as glossy as I expected. Is this normal or am I being to picky?
all parts of the tractor were previously stripped and primered.
CNKS
02-05-2004 18:12:35
 Re: glossy paint in reply to jake, 02-05-2004 06:53:17
One other possibility is the difficulty of painting all the irregular surfaces of cast. It is easy to "double coat" or make a partial pass on an ares you just painted. When you do this, you are painting over a previous coat that has not yet "flashed". This can cause dieback, or dulling of the surface. I am often tempted to make a second pass on something I did not get quite covered -- not a good idea.
Joe Evans
02-05-2004 07:35:10
It is likely not as reflective as the sheet metal because the cast iron surfaces are not near as smooth as the sheet metal surfaces. The irregularity of the cast iron suface breaks up the light reflection.
w gatewood
02-05-2004 11:44:17
 Re: Re: glossy paint in reply to Joe Evans, 02-05-2004 07:35:10
very well spoken joe, i have painted several tractors and he also needs to let the paint cure it will change a little but as joe stated its cast iron a totaly different type of meterial than the sheet metal
