F20/F30 round spoke fronts
Toot
02-05-2004 08:22:02
I was wondering if the round spoke front of a F20 will fit a F30. The early JD A & G front hub would interchange, so I was wondering if the same applied on those. I have a extra round spoke 20 wheel lying around, and have aquired a F30 tractor with one bad round spoke wheel. Thanx
G Conn
02-07-2004 18:11:25
 Re: F20/F30 round spoke fronts in reply to Toot, 02-05-2004 08:22:02
Toot, I to had a bad spoke wheel on a f30 , the f&h number cast in the hub was the same for a f20 and f30 but as I remember there is a difference on the inside bore where the grease seal wear sleve goes. I took mine to a machine shop to have it inlarged.
Nebraska Cowman
02-05-2004 09:26:37
toot, the parts book calls for a different number but the hubs for the steel wheels are the same number, go figure, i think it will fit but you will have to check it on the tractor to be sure.
Bobcat
02-05-2004 12:03:19
 Re: Re: F20/F30 round spoke fronts in reply to Nebraska Cowman, 02-05-2004 09:26:37
I have a F30 that came with front wheels off a 39F20. I replaced with steel F30 wheels/hubs/bearings. They fit just fine onto the front axles.
