B Farmall Serial Number
M. McMurtry
02-05-2004 11:16:32
WE are doing a B Farmall for an ag. mechanics project for local and state fair competition.
Getting conflicting information on serial number so we can pinoint vintage. Old folks
say is was bought 1939 or 40. Serial number says 41 model. Serial on plate under seat,
someone said wrong place. Should be on left
side of clutch or trans. housing.
Help! Quick!!
M.McMurtry
02-06-2004 09:37:00
 Re: B Farmall Serial Number in reply to M. McMurtry, 02-05-2004 11:16:32
Thanks for your responses. Have following numbers
numbers: on chasssis lft side 8638DA, top of transmission 6832DA, engine 2*2*J, plate under
seat FAB 46,189. If this is a 41, could it
have been purchased in fall or winter of 40.
Old folks still say they had it in late 40 before
they moved to town in summer of 41. Again
thanks for all the info so far. Also trying
to find exact info. on decal plaecment. Tractor
had original battery box, draw bar, and belt pulley.
Bull
02-05-2004 18:31:53
I have a 1939 "B". It was made in about the first month of production. The Serial Tag is located on the front of the clutch and brake pedal guard. As others have pointed out, except for the very early ones the serial tag is located under the seat.
Red Dave
02-05-2004 12:20:51
It will NOT be on the clutch housing. If it is a very early model, it may be on the pedal guard below the brake pedals as ihkovas indicated. Otherwise, it should be on the inside of the left-hand seat bracket.
My '40 B serial number plate is on the seat bracket.
You can also check out the engine serial number, which is located on a raised boss on the right-hand side of the block, below #1 plug, kinda behind the magneto. On the early models, it would be the same as the tractor serial number.
'39's & '40's can also be indentified by the Dzeus fasteners on the hood, instead of the later "J" hooks.
ihkovas
02-05-2004 11:52:47
McMurty and Dave, On the 1939 and early 1940's A and B's,the serial number plate was located on the front of the clutch and brake pedal guard. I'll try to post a picture later today.
Dave_Id
02-05-2004 11:25:50
Check out the casting dates... 3*16*J with the asterisks looking like slotted screws. The J stands for 1940, K is 1941. 'I' is "39" Keep in mind, that is was when the parts were cast...actual assembly came later...
Dave_Id
02-05-2004 11:27:42
 Re: Re: B Farmall Serial Number in reply to Dave_Id, 02-05-2004 11:25:50
Ser # is supposed to be on a plate on the inside of the left seat bracket... The H, M , and some others are on the trans housing...
