340 trans/hydraulic filter location
Al L. in Wisc.
02-05-2004 19:52:49
Where is the trans/hydraulic filter located at? Drained the fluid from three plugs; was a slight caramel color. Had heat in the garage for about five hours before draining. Some small shavings in the big plug. Have new fluid in the house tonight so it flows tomorrow. Thanks in advance.
w gatewood
02-05-2004 20:07:17
 Re: 340 trans/hydraulic filter location in reply to Al L. in Wisc., 02-05-2004 19:52:49
the filter is located on the right hand side of your tractor just in front of your brake pedles. it has 8 bolts i think in this cover and the cover is sort of shaped like a football. when you take off the cover there will be a sump screen stuck in the filter just wash out the sump screen with parts washer fluid or gas and dry it out and replace it when you put on a new filter and if you get the hyd system over full don't worry about it its ok.
