Super H vs H
Bill Ramsey
02-06-2004 08:15:22
I have a super H that the rocker arm and push rods were missing. Are they the same as H or do I need to get super H rocker and push rods? Thanks in advance Bill
Dave42H
02-08-2004 05:07:57
 Re: Super H vs H in reply to Bill Ramsey, 02-06-2004 08:15:22
Bill I have a extra set of push rods and rocker arm assemble from a H if you want them no charge.
randy hall
02-07-2004 11:48:00
i have an old advertisement that shows twentyone improvements for the super h over the straight h. the original sleeves in a super h are the same thickness as a straight h.
Bill Ramsey
02-06-2004 18:53:28
Thanks Guys. Just about to get it unstuck so can go back together. Thanks. Bill
Chad
02-06-2004 09:31:12
They will interchange with each other. Chad
MAP
02-06-2004 11:02:23
 Re: Re: Super H vs H in reply to Chad, 02-06-2004 09:31:12
Didn't the Super H have a bigger engine than the straight H??
Theman
02-06-2004 11:46:28
 Re: Re: Re: Super H vs H in reply to MAP, 02-06-2004 11:02:23
Yeah, a little bigger - by about 10 cubic inches or so. It was more of a horsepower tweak than an upgrade.
rustyfarmall
02-06-2004 12:14:55
 Re: Re: Re: Re: Super H vs H in reply to Theman, 02-06-2004 11:46:28
The super H has thinner sleeves, thus giving it a larger bore, which equals more horsepower. It also uses a bigger carburetor. Pretty much everything else is the same.
Gary
02-07-2004 07:11:05
 Re: Re: Re: Re: Re: Super H vs H in reply to rustyfarmall, 02-06-2004 12:14:55
Don't forget the head. Later model Supers were way different too.
