Re: 52 farmall super c
Farmall-Nut
02-06-2004 18:58:16
Jim, Before you tear into the gov. I would check the gov. rod itself. Take the cotter pin out of the back of the carb and make sure that your rod is allowing full rpm. It may take a little wd40 but you should be able to adjust it. Hope this helps ED
