Trans. Brake Adjustment
Dan
02-09-2004 05:19:51
We have a 3588. The transmission brake linkage has the clevis I am used to, but above that, in the linkage, is a chrome cylinder with a grease zerk on one end. Is this an aftermarket kit? What is the proper way to adjust it? I assume you press the clutch down, then add grease to the cylinder until it presses the brake tight? Any help would be great!
RB
02-09-2004 08:29:00
 Re: Trans. Brake Adjustment in reply to Dan, 02-09-2004 05:19:51
The grease fitting is for lubrication, there is a spring inside the cylinder, adjust it normally or a little longer to make use of the spring action. This spring loaded setup does work better, just remember the pad on the inside does wear out.
Dan
02-09-2004 10:43:39
 Re: Re: Trans. Brake Adjustment in reply to RB, 02-09-2004 08:29:00
Thanks, RB, big help!
