Tachometer
Male Gayle
02-09-2004 09:50:23
Can a tachometer from a 300 Utility be used on other farmalls? Would the difference in gearing to get accurate readings depend on the gearing in the distributor drive and cable, or in the body of the tachometer itself? Thanks for any replies.
Dave
02-09-2004 10:12:13
 Re: Tachometer in reply to Male Gayle, 02-09-2004 09:50:23
RPM same;Ground speeds would be off on face.
Dave
02-09-2004 16:02:20
 Re: Re: Tachometer in reply to Dave, 02-09-2004 10:12:13
The parts that drive tach are same for RC. or
utility.difference is tire size and ring and pinion and RPM. between tractors.even though RPM
would show on tach the same RPM for both tractors
the utility will be marked for higher max RPM.
Because of gearing and tire size on tractors the ground speed markings will be off when switching tach.Hope IM MAKING SENCE.
Male Gayle
02-09-2004 15:22:11
Thanks, Dave. Is that due to the internal gearing of the tach or the cable gearing?
rebuilder
02-09-2004 17:09:40
 Re: Re: Re: Tachometer in reply to Male Gayle, 02-09-2004 15:22:11
Male Gayle;
The distributor tach drive is the same for all four cylinder distributors(I.H.) and the cable would not change anything. Any change in rpm for different tractors is made inside the tach.
Male Gayle
02-09-2004 18:01:39
 Re: Re: Re: Re: Tachometer in reply to rebuilder, 02-09-2004 17:09:40
Many thanks to you both. Appreciate your help.
