Talk about luck!!!
49 Cubber!
02-09-2004 15:55:27
Well,I was all set to pull the top of the tranny back off of my H this afternoon top get the forks back right and I wanted to see which one I missed,so I took off the steering column,the seat,the tank,took all the bolts out and pryied up on the cover with a prybar and took a ppek inside.My first thought was right,missed 2nd and 3rd slider.The more I looked I got an idea,IF I could get it up just enoguh to move the gear in the right place,and I did it careful enough,I wouldnt have to pull the top and repalce an expensive,didnt fit right to start with unitl I modiifed it a little gasket!slide the gear back about a 1/4 inch,eased the top down and Whamo! problem fixed and to my surprise,after abotu two hours of riding the kids,not a single leak form the top..... ..... .YET!
lee
02-09-2004 17:52:46
 Re: Talk about luck!!! in reply to 49 Cubber!, 02-09-2004 15:55:27
Glad you got lucky but really not that big a deal to pop the top and get it back down on there. Select a gear on the top to position the forks. Move the gears into that position manually. Put the top down straight on and get each fork in a groove. Done. 5 or 6 tries you're done.
Place two bolts and test it. What's the big deal.
49 Cubber!
02-10-2004 01:58:14
 Re: Re: Talk about luck!!! in reply to lee, 02-09-2004 17:52:46
I like that,5 or 6 tries..... ..Accually,this is only the third top,betweem my two Ms and this H,that I didnt get it the first time.Of course this is the first top Ive pulled in about 7 years and the last one I had help on.Idid this H top alone!
JF
02-09-2004 17:19:13
GLAD TO SEE SOMEBODY HAVING SOME GOOD
Jim in michigan
02-09-2004 16:47:57
Congrats on the easy fix ,,, do you recall the price of that Cub axle housing? I know this one is broke, guy told me it was and that it needed a axle,, Thanks,,,,Jim
Farmer Bob
02-09-2004 16:38:29
Gotta love it when things work out like that. It kind of makes up for all those other cursed moments when nothing seems to go right!. Good on ya.
49 Cubber!
02-09-2004 17:04:18
 Re: Re: Talk about luck!!! in reply to Farmer Bob, 02-09-2004 16:38:29
Come close a few times to lettin one or two out,but knew it would all work out in the end!
