3 point hitch kit for Farmall A?
Tom Williams II
02-11-2004 06:59:17
Hi! Can any of you tell me where I might find an adapter kit or whatever to make a 3 point hitch fit on a Farmall A? I have looked a lot and still have had no luck.
Also looking for a Belly Mower for an A. Thanks
Tom
gene b
02-12-2004 02:27:30
 Re: 3 point hitch kit for Farmall A? in reply to Tom Williams III, 02-11-2004 06:59:17
How do you plan on powering your hy-pump if you also want a belley mower.
Tom Williams III
02-12-2004 06:25:57
 Re: Re: 3 point hitch kit for Farmall A? in reply to gene b, 02-12-2004 02:27:30
Am thinking about using a 12 volt electric pump. Either that or a GM power steering pump. What would you recommend. I would prefer electric or pulley so the hydraulics would still be active when the clutch is engaged.
All ideas are appreciated.
Tom
Songsmith
tiny
02-11-2004 14:08:55
For the farmall A you would have to get the three point for the super A and adapt it plus put hydrulics on your A it can be done with some work.
