O S-6 shifter
Randy
02-11-2004 12:28:20
Just bought a 1949 o s-6 and it won`t go into forth or fifth gear.All other gears work fine.What do I have to do to find out what the trouble is?Do I have to take the top off the tranny?If so how do I go about it,and what do I look for? Appreciate any help,Randy.
Nebraska Cowman
02-11-2004 16:15:15
 Re: O S-6 shifter in reply to Randy, 02-11-2004 12:28:20
Oh, not knowin nothin about it I would say it might be the shifter rail is stuck for those gears. If it was frezing weather I would not even mess with it till it warms up cuz it may just be ice. otherwise could be rust. I might try gently forcing it by using a bar through the shifter hole but bear in mind if the rail is free and the gears are stuck you could break a shifting fork. But oh well, then you will get to take the cover off, might be worth a try, your call.
