656 oil leak
Brad in SD
02-11-2004 15:05:58
My son was blowing snow, he told me oil started to shoot out from under the floor pan. I have not checked problem out yet, I'm 1300 miles from home at this time. What could the problem possibly be, and what is the cause? The tractor is a 656 gas, with an IH 3000 loader and a rear mount snowblower. Thank You for any insight.
Nebraska Cowman
02-11-2004 16:08:42
 Re: 656 oil leak in reply to Brad in SD, 02-11-2004 15:05:58
yup, ther's steel lines under there and they rust out. can be fixed by brasing if you or your boy are clever.
Poor So. IL. Farmer
02-11-2004 15:39:22
Sounds like you may have blowen one the hyd. lines going up to remote block under the steering pedistal.You should have 2 to 4 lines under the platform.I had this happen on my IH F806.Good luck hope this helps.
