49 Cubber!
02-11-2004 16:24:11
#3 cylinder,it starts up great runs maybe 4 or 6 seconds and starts missing,just on that cylinder.I thought maybe a valve problem since I just put new,plugs,wires,points,condensor,cap and rotor.Compression was pretty equal on all 4 so I pulled the valve cover and all of them were set near perfect.Now,I started it back up and pulled one wire at a time off and on #3 you can see a spark jump,but not all the time,when it sparks,the plug fires and the tractor perks up for a second or two and all this starts back up. Ithought mabe a bad plug or maybe a bad wire or even a bad cap,but after changing the plug with another plug on the tractor and same for the wire,and taking the cap off of my restored M and it doing the same thing I dont think any of that was bad.When I put the cap from my H on my M it doesnt skip on #3 like on the H so I can rule that out.Could it possibly be the lobe on the point shaft is work just on #3 and not letting the points open enough on that cylinder.Oh,almost forgot,this is jus at idle,when I get above half throttle,it clears up and runs fine and its a distributor ignition.Thanks!
