anyone on this morning to help with points problem
rex
02-13-2004 06:54:59
I am working on a 444 bought the tractor as is not running put in new points this morning I have fire when I ground out the points with a srewdriver to the distributor but none between the contacts cleaned everything and tried a different coil same results anyone out there this morning that can help. Thanks Rex
Jim in michigan
02-13-2004 06:59:27
 Re: anyone on this morning to help with points pro in reply to rex , 02-13-2004 06:54:59
I had that happen once and it was a faulty set of points, I returned them for a different set...Jim
rex
02-13-2004 07:06:57
 Re: Re: anyone on this morning to help with points in reply to Jim in michigan, 02-13-2004 06:59:27
Thanks for the post Jim this really has me confused the old points I took out were doing the same thing, it is real easy now to know why I switch my 240 over to the petronix ignition I have had that on that tractor for over 5 years and never had the cap off. Thanks Rex
Mark
02-13-2004 07:51:42
 Re: Re: Re: anyone on this morning to help with po in reply to rex, 02-13-2004 07:06:57
Rex,
I do it as a matter of habit. If a gasser hits my farm, the first thing I do is rip out the points and put in the magnetic pickup and electronic ignition with the 50,000 volt coil. The next thing I do is get some hot spark plugs that have the long insulator which makes them stick down into the combustion chamber, rather than flush with it like plugs were 40-100 years ago. The hotter plugs have thinner metal parts which get hotter and burn off the crud. Then I set the gap aroung .050 so that that 50kv coil has time to really suck in some joules (watt-seconds of energy to smack the plugs). Course, before I install them I measure my clearance over the piston at full up (TDC when measuring #1). Then one final check is a roll over by hand to insure that nothing hits. Then the final check is to insure that I have a 180 degree thermostat to insure that the engine gets hot enough to burn off the condensation in the cylinders..... Then fire that baby up, twist the distributor right to miss miss miss, left to miss, miss, miss and half way inbetween...lock her down.
Then wait until the temp gauge settles out around 180 and kick her down to idle and listed to her hit on every one....you'd think she was a diesel..... ..... ..... .....AHHHHH HH life is sweet.
Mark
rex
02-13-2004 12:08:10
 Re: Re: Re: Re: anyone on this morning to help wit in reply to Mark, 02-13-2004 07:51:42
Heres one for you all could get no fire to the points, fire there just not on the contacts, took a piece of aluminum foil placed it between the contacts VOOM fired right up. sometimes this stuff will drive you crazy OH BUT AIN"T IT GREAT.
