Skip solved!
49 Cubber!
02-13-2004 18:11:45
Still dont know exactly what was causing #3 to skip,but the distributor swap cured it.I put the one from my Hon my M and it had the skip on #3,just like the H.Oh well,time to head to the salvage yard!
lee
02-13-2004 18:20:34
 Re: Skip solved! in reply to 49 Cubber!, 02-13-2004 18:11:45
The distributor shaft may be slightly bent or the bearing worn or the rotor is not on there square to the axis of the shaft or the cap is not all the way down on square. One or another or a combination of these may be causing too much gap between rotor and cap post #3. Just a guess.
I could be wrong as I have been in the past.
