belly mount weight bracket
Tye
02-14-2004 17:06:11
Ok, I posted this question on the JD board and the pullers board with no luck. Can anyone help me on designing a belly mount weight bracket for my JD 50 for tractor pulling? Please don't descriminate against me because my tractor's not red. I like the red ones too. If anyone has some dimensions or a photo of theirs or something, I would greatly, greatly appreciated it. Thank you very much.
ny bill o
02-15-2004 13:07:37
 Re: belly mount weight bracket in reply to Tye, 02-14-2004 17:06:11
i built one for my 560 out of 3x3x1/4" angle iron. i cut 2 pieces about a foot and 1/2 long for vertical pieces, blew hole in top with torch for 3/4" bolts into 560 frame. i used more of the same angle, just a couple inches narrower than the inside tire width, and welded the 3 pieces together. added a plate on each end of horizontal piece so weights can't slide off and hit tire. i've seen some that had an angle brace back to the tractor but mine doesn't have one. i tightened the bolts tight and it doesn't move. not fancy but it works. my digital camera is on the blink so i can't give you a picture.
Tye
02-15-2004 18:31:50
 Re: Re: belly mount weight bracket in reply to ny bill o, 02-15-2004 13:07:37
Thanks Bill, That helps me out alot. Have a great day! -Tye
