300 12 or 6 volt?
ron
02-14-2004 22:52:00
hello everyone,does anyone know if a 56 300 is 6 or 12 volt? also what kind and how much oil goes in the t/a and tranny? thanks all....
TDK
02-15-2004 18:55:23
 Re: 300 12 or 6 volt? in reply to ron, 02-14-2004 22:52:00
Manual says 7 gal. trans/diff. combined. Hy-Trans ONLY!!
old
02-15-2004 08:45:37
It could be either now, came in 6 volt but could have been changed. If it has a genarator its probably 6 volts, but if it has an alternator its probably 12 volts
Hayshaker5
02-15-2004 05:53:37
The 300 had 6 volt systems. Would suggest getting an Owner's Manual either from the Marketplace Links to the left of this screen or at your local Case IH dealer. The manuals have all the original specifications for your tractor and has Lube guides and light service procedures. I purchased a 560 Farmall several years ago, and although I grew up with one and many other Farmalls there is still valuable information you can use.
rustyfarmall
02-15-2004 04:34:35
Originally 6 volt. Hy-Tran in the tranny. Don't know how much.
Brian Schmidt
02-15-2004 19:41:03
 Re: Re: 300 12 or 6 volt? in reply to rustyfarmall, 02-15-2004 04:34:35
Are you guys sure about the Hy-Tran in the tranny? I thought these used gear lube? Isn't the XMSN basically the same as an H?
26Red
02-16-2004 10:54:10
 Re: Re: Re: 300 12 or 6 volt? in reply to Brian Schmidt, 02-15-2004 19:41:03
Hy-tran is a little too thin- you'll be grinding gears trying to shift, because everything is still spinning. A heavy gear oil is the best.
