carb farmall h
kurt
02-15-2004 04:07:11
I need a carb rebuild kit for an h. any ideals where i can find one at?
thanks
Dave S
02-15-2004 07:07:58
 Re: carb farmall h in reply to kurt, 02-15-2004 04:07:11
Mike at Steel Wheel Ranch carries them, think they are around $25 or less. The phone # is 785-548-7437 and I think the web address is www.steelwheelranch.com
Paul in Mich
02-15-2004 07:22:39
 Re: Re: carb farmall h in reply to Dave S, 02-15-2004 07:07:58
Dave, is what they have at S.W.R. IH or aftermarket, or either? Just curious
Dave S
02-15-2004 10:50:22
 Re: Re: Re: carb farmall h in reply to Paul in Mich , 02-15-2004 07:22:39
The I bought is a complete kit, TISCO #C510HV for oem carburator #5098DA, it has the throttle shaft, choke shaft, choke plate, jets gaskets etc. He also had partial kits. I looked on the package and mine cost $22.50 for the complete kit, don't remember what the partial cost. I picked it up at his shop so there will most likely be shipping to.
Paul in Mich
02-15-2004 05:45:26
Kurt, If you find IH a little pricy, you can try Tractor Supply (TSC) they have a complete kit for under $30.00. the only thing is that you will probably have to file the choke butterfly to fit but if your old one is good you dont have to use the replacement.
KURT (mi)
02-15-2004 04:16:14
Most CaseIH dealers have them, Do a search on the net for dealers and see which one is closest to you.
