F-30 Question
Mike
02-15-2004 17:21:51
Can someone please explain how the rocker-arm lubricates on a F-30.
Cecil Nuckolls
02-16-2004 09:17:15
 Re: F-30 Question in reply to Mike, 02-15-2004 17:21:51
The plug is on the outside between #2and #3 cyl the tube on inside will have to be squeeze down to slow the flow.
dlp
02-15-2004 18:58:05
There was a line kit offered that would pump oil up to the tray. I noticed it in my W-30 manual, which used the same engine.
Cecil Nuckolls
02-15-2004 18:48:57
You coan fix them to oil from the oil pump. there is a plug in the head that you can put a line from the fliter to and make a tube in the head to flow oil into trough on the rockers
Fred Milner
02-15-2004 18:57:10
 Re: Re: F-30 Question in reply to Cecil Nuckolls, 02-15-2004 18:48:57
Have you done this? Where is the plug and how do you go about doing that. Will it work on the F-20 and F-30? Can it put too much oil on the rockers and cause it to smoke and use oil? That would be a good thing to do if it works out. More details would be nice. Thanks Fred.
Mike
02-15-2004 17:37:39
Thanks for the reply Bob. Were all F series rocker-arms lubricated by manual oil cans?
Bob
02-15-2004 17:27:16
I think you have to pour oil throught the tube's on top of the valve cover and this will travel into a wick lined trough that runs the length of the rocker arm.
Fred Milner
02-15-2004 17:42:05
 Re: Re: F-30 Question in reply to Bob, 02-15-2004 17:27:16
That is the way you oil them. The F-30 has an oil pad instead of wicks but they dry out and get hard from time and heat. If the pad in the F-30 or the wicks in the F-20 have not been replaced for a long time you would be money ahead to take the valve cover off and replace them. It does no good to pour oil in the trough and it run right out on one or two rockers and leave the others dry. I have taken the valve cover off my F-20 and F-30 to find the wicks and pad hard and broken up. They were not working very good if at all. You can get the parts from Rice Equipment. Not a hard job at all. Good luck
The Red Barron
02-16-2004 03:03:36
 Re: Re: Re: F-30 Question in reply to Fred Milner, 02-15-2004 17:42:05
I still have not really seriously tore into the F-20 that I have awaiting a restoration but I am curious. Are you saying that short of what a person puts through the oil cups on top of the valve cover that the rockers get no other oil once it is running?
dlp
02-16-2004 19:15:47
 Re: Re: Re: Re: F-30 Question in reply to The Red Barron, 02-16-2004 03:03:36
Oil cups? The 2 cups on top of the valve cover are for pouring gas down into the intake prior to starting. Pour oil in thru the big single cap on the cover.
Fred Milner
02-17-2004 14:38:47
 Re: Re: Re: Re: Re: F-30 Question in reply to dlp, 02-16-2004 19:15:47
The F-30 has one hole with a cap the F-20 has 2 holes much smaller and they have spring caps on them. Sorry but I thought everyone with one would know that the primers were not what we were talking about.
Fred Milner
02-16-2004 05:08:33
Yes that is what I am saying. The only oil the rockers and valves get comes from the wicks and they are oiled only from the oil you put in the trough through the holes in the valve cover. That is why it is important to oil them often. I don't run mine a lot so I oil them every time I use them. As I said you need to know if the wicks are good. If they are not they will not oil like they should and you will have a problem in time. They are not hard to cheak and fix but need to be done. Good luck.
The Red Barron
02-16-2004 09:28:15
 Re: Re: Re: Re: Re: F-30 Question in reply to Fred Milner, 02-16-2004 05:08:33
Whoa! I didn't realize that but it certainly is a good thing to know. I'll have to add to the list. Thank you.
Mike
02-15-2004 17:44:02
Thanks Fred
Fred Milner
02-15-2004 18:15:01
 Re: Re: Re: Re: F-30 Question in reply to Mike , 02-15-2004 17:44:02
Mike The F-12 And F-14 have the rockers oiled form the oil pump. I don't know why the F-30 and F-20 were hand oiled. I think the pump method is a lot better because people might not get enough oil on the rockers by hand. How long have you had the F-30?
Mike Holloway
02-15-2004 19:00:24
 Re: Re: Re: Re: Re: F-30 Question in reply to Fred Milner, 02-15-2004 18:15:01
Hello Fred, actually I have a F-20. It has been in the family since new. Belonged to Grandpa. Serial No.FA-63269. Set in a well protected barn for all it's life. This one has the faster road gear. It is a real cherry. We started it this afternoon. First time it has ran in over 30 years. Mike
