h oil pressure
rman
02-15-2004 20:12:38
can anyone tell me how to adjust oil pressure on h do you have to pull pan thanks in advance rman
riverbend
02-16-2004 07:15:32
 Re: h oil pressure in reply to rman, 02-15-2004 20:12:38
There is a oil regulating valve in the oil pump, but it is not likely to be the problem unless the pressure is too high. The most reliable way to increase the oil pressure is to replace the bearings. In either case, you will need to remove the oil pan.
