460 hydraulics
Calvin Rollins
02-16-2004 03:03:53
On my '59 Farmall 460 I was advised to drain the hydraulics and fill it with k1, run it around a little to warm it up then drain it, change filters and refill with new hydraulic fluid.This was supposed to clean out the system. So what do you all think? Should I do it or not?Thanks for your input.
Jerry
02-16-2004 05:40:02
 Re: 460 hydraulics in reply to Calvin Rollins, 02-16-2004 03:03:53
I have heard this method to be used in old dirty engines. But one reason it bothers me is an old mechanic told me that diesel or keorosene has no lube properties. To prove it he told me to dip my fingers in the fuel then snap my fingers. On engine bearings humm probably be a little rough on em. I don't know what it would do to brass bushings and thrust washers in your pump. But I bet the crud it breaks loose in the bottom of your housings probably aint gonna help it either.
scotc
02-16-2004 21:08:00
 Re: Re: 460 hydraulics in reply to Jerry, 02-16-2004 05:40:02
I'd be leary of running kerosene somewhere thats made for what, 10 or 15 weight oil? I'm not sure I'd want to try adding a little to the hytran unless someone else was paying the bill.
