Water jacket on a H
bdeerehunter
02-16-2004 17:12:26
Here's my problem, I am in the process of a total rebuild on a H Farmall and when I removed the left side cover on the engine to look inside the water jacket, I could see the cylinder sleeves. Now that dosen't sound bad but, unless I am mistaken, the H has dry sleeves right? If in fact it does, What could I do to put it back like it should be? (some kind of metal welded back in between the jacket and sleeves) As my screen name says, I mess with mostly Deere equipment but I love all of them. Any help is appricated.
Dave S
02-16-2004 21:19:17
 Re: Water jacket on a H in reply to bdeerehunter, 02-16-2004 17:12:26
I bought a new cover for my H from Sreel Wheel Ranch for $20.00. Phone785-548-7437 www.steelwheelranch.com
CNKS
02-16-2004 18:19:24
Nebraska Cowman is correct -- Probably more surface area for the water that way. You can still get a new cover from Case-IH, yours is probably shot.
Nebraska Cowman
02-16-2004 17:23:08
unless someone has done major surgery to your h you were not looking at the sleeves but the outer jacket around them. That's what makes them dry.
bdeerehunter
02-16-2004 18:19:28
 Re: Re: Water jacket on a H in reply to Nebraska Cowman, 02-16-2004 17:23:08
That's exactly what I am looking at. I just couldn't explain it the way you did. Have you ever tried or heard of anybody replacing or fixing those outer covers before? thanks again.
Wayne Swenson
02-16-2004 20:53:06
 Re: Re: Re: Water jacket on a H in reply to bdeerehunter, 02-16-2004 18:19:28
Should be able to find one on E-bay or your nearest salvage yard.
