400 or M venturi needed
Zak
02-17-2004 16:08:18
Need a 400 venturi as my IH dealer doesn't stock them anymore! Anyone got one in good shape they'd part with? Thanks, Zak
rebuilder
02-18-2004 11:32:22
 Re: 400 or M venturi needed in reply to Zak, 02-17-2004 16:08:18
Zak;
The venturi you need will have a #27 cast into the top. Many of the carbs have the same venturi Part number(cast into side of venturi) but different casting #'s. For example Super H-#23/300&350-#25/M,400,450-#27...all the way up to C-301engines with #35. The casting #'s correspond to the diameter of the inside of the venturi.If you have trouble finding the one you need, I have quite a few left over from junked carbs during rebuilding. Post back to get ahold of me.
Ted
02-19-2004 10:57:33
 Re: Re: 400 or M venturi needed in reply to rebuilder, 02-18-2004 11:32:22
Zak, Are all venturis the same size for M thru 450? Have you ever seed one that is larger and that would fit it an M thru? If so do you have one?
Ted
02-19-2004 11:00:00
 Re: Re: Re: 400 or M venturi needed in reply to Ted, 02-19-2004 10:57:33
Sorry, I ment to send that last note/question to rebuilder
Zak
02-18-2004 19:28:00
Thanks guys, I found one. The one in my 300 has a #25 cast into it.
jim in ny
02-18-2004 05:17:46
call faust bros repair . he has them. dont have his number handy but he always has a add in redpower if you cant find # post back I WILL GET IT FOR YOU
