super a valve springs
derek
02-18-2004 17:40:14
could someone explain how to remove the retainer pin on the valve to remove the springs. do i need a special clamp of some kind. been trying all after noon cant get them off. thanx
Stan(VA).
02-19-2004 04:36:07
 Re: super a valve springs in reply to derek , 02-18-2004 17:40:14
You need a valve spring compressor (looks like a big C clamp that goes from head of valve up around the top of valve spring). After you compress the valve spring, you remove the keepers (which are in two parts), then release the compressor, remove the spring and valve.
Stan(VA).
derek
02-19-2004 11:13:21
 Re: Re: super a valve springs in reply to Stan(VA)., 02-19-2004 04:36:07
thank you for the info
