Super M; to buy or not to buy
RayA
02-19-2004 18:52:21
Hey guys, I just went to look at a super M.. good paint, good tin, precleaner, narrow front, tired very good, has rear light and some makeshift front lights. Also has a toolbox bolted onto side frame. Was supposed to have run when parked a year ago, now it turns over but doesnt run. Owner said it was making noise when parked like it might have spun a bearing or had something wrong with one of the cylinders. It has been converted to 12volt and gas tank is a bit rustyb but had gas coming out of carb like it was flooding... the asking price is 800. Should I jump on this or let it pass. Located in OK. Has belly pump and belt pully also..serial # is f23784j...thanks ahead for comments. RayA
Jon
02-20-2004 10:21:09
 Re: Super M; to buy or not to buy in reply to RayA, 02-19-2004 18:52:21
Make dahm sure that the moter doesnt have antifreeze in the oil. Or vise versa oil inh the antifrezee. Crack the valve were the antifreeze drain plug and if a little oil come out then you have a problem M and H models are know for that. Make sure you check it before you buy the trcator.
RayA
02-20-2004 09:50:30
Thanks for you comments guys, I will probably try to give the guy a call tonight and see what we can bargain out.RayA
REDS
02-20-2004 05:21:16
With good tires and since the engine is not stuck, it is worth $800 here in Maryland.....easily. Offer him a little less and see what he says. Don't wait too long, someone else might come with the cash!!
Dale in Ar.
02-19-2004 20:31:12
Ray,from your discription,I'd say go for it.With a rebuild,you would have $1800. in a good looking tractor.Then again,you could offer $500 and then go up from there.You never can tell,he might come down.
Hayahuler
02-19-2004 20:05:14
Ray if you are needing a Super M in Ok, we have one near Lawton that runs great (under 500 hours on motor), great tires (85%or more), needs paint, 12 volt, belly pump, factory LPG, serial F-29691CJ will take $1800.00 and let you hear it and see it work. Kevin
CNKS
02-19-2004 19:27:56
Super M in good condition is worth about $1500. It will cost you about $1000 more or less for the engine work if you do it yourself -- so I agree with the others, $500.
Hugh MacKay
02-19-2004 19:25:34
Ray: Of course you should, from your description, not stuck and a Super M. By all means get out your check book, before someone else gets their's out.
old
02-19-2004 19:20:31
Hows the tires? figure that if they are good say 75% or better thats $300-$500 and then the rest is gravey. I'd offer $500 and see what happens, you will probably need a rebuild on the engine/ carb etc so your looking at $1000 to get it up right then theres paint.
BB
02-19-2004 19:20:19
If I wanted one I think $500 would be a decent buy for the shape its in.
Andy in Ohio
02-19-2004 19:14:12
Ray, sounds a bit high if it has a noise in the engine,but at least he told you it had a noise. Offer him 600.00$for it, that 200.00 saved will help with high price of an overhaul. Either way its your money so have fun! My 2cents, Andy
