Super H wide front
tom
02-20-2004 03:52:24
will a wide front axle from a Farmall 400 fit a Super H?
Red Rider
02-20-2004 19:10:14
 Re: Super H wide front in reply to tom, 02-20-2004 03:52:24
Zak, yes the wide front off tractors clear up to the 1206 will fit your Super H. The only thing that is different is the rear stay rod bracket. The frame on your Super H is narrower. The rear bracket is pretty hard to find and If you do pretty expensive. I have a wide front on my 300 Farmall off a 806 and I built the rear stay rod bracket. Its pretty simple to build. I will take a picture of it and see If I can figure out how to post it here. If I can't look on the Red Power Forum and It will be there.
Zak
02-20-2004 06:41:06
I'm gonna put myself on a limb here and say no. I just put a 560 WF on my 300 and the bolt holes are about 1/2" further apart on the 400's front end (same as for M and up) than they are on the narrower H-350 series pedestal. Additionally, the mounting bolts are 3/4" on the bigger series as opposed to 5/8" on the smaller. HOWEVER, this doesn't mean you can't use it! All you have to do is drill smaller holes 1/2" in towards the centers to mount it. OR, as I did, cut the pedestal mounting plate off the bracket on your WFE and make a new plate out of 1/2" steel with the proper moutning holes. Then, just MIG weld it on and you're good to go. You may have rear support mounting issues as well, but I made my own plates there. It all depends on your ability to "make do" with what you have, or sell it and find what ya need! Good luck, Zak
Red Rider
02-20-2004 19:13:51
 Re: Re: Super H wide front in reply to Zak, 02-20-2004 06:41:06
Zak, I just remembered that the steering bracket that bolts to the bolster Is also a little different. Solution is to make a card board templet and just oblong the holes to match. Again If you can find one for the H you will pay dearly for it. I still haven't been able to find one and I have been looking for over 5 years.
Zak
02-20-2004 19:48:24
 Re: Re: Re: Super H wide front in reply to Red Rider, 02-20-2004 19:13:51
I ain't the one that asked the question, Tom was, but thanks for seconding my findings anyway. :) Zak
