Hy-Tran or Hy-Guard (Deere) or Ambra (Ford)or 30 w
John
02-20-2004 06:49:40
What is the wt. of Hy-tran? The reason I am asking, I am rebuilding my hydraulic cylinder I use with my Farmall H and am thinking of running hy-Tran or Ambra instead of 30 wt. non-det. in my Farmall H Lift-All so everything would be compatable with my other tractor. I just put new Ambra multi G 134 nh 410B (Ford Brand) in my Ford 5600, I figure Hy -Tran must be compatable with Hy-guard (John Deere), Ambra (Ford) . Or maybe I should just stick with Hy-Trans or 30 wt. non-det. in my Farmall H lift-all and keep a seperate Hydraulic cylinder to just use with it? Thanks!!
John
02-21-2004 06:41:45
 Re: Hy-Tran or Hy-Guard (Deere) or Ambra (Ford)or in reply to John, 02-20-2004 06:49:40
Thanks guys!!
Mark
02-21-2004 06:36:20
I buy it at a local farm store (Gebo's) and it comes from a refinery in Okla. On the back of the bucket are specs for almost every tractor imaginable....meaning they must all be pretty much the same. And as I recall the weight is about 15w.
Mark
42FarmallH
02-20-2004 17:11:14
I use Hy-Tran in my Farmall H liftall with no problems. And I have the old pump that only puts out 450 psi max when new...
rustyfarmall
02-20-2004 07:19:31
No problems at all, use whatever you are using in your other tractors.
Dan
02-20-2004 07:09:32
According to my local farm cooperative, hy tran and Hy guard have the same specs. They have their own oil called Quicklift. Several years ago when I overhauled the TA on my SMTA I replaed the transmission oil with a hy tran equivelent on advice from here. I use that same oil in my hydraulics. I also use it in my JD430 and MT hydraulics. Seems to work well.
