444 hydralics question
rex
02-21-2004 12:26:57
I don't yet have a manual for this tractor but I have a leak around the horizonal small plunger in the back side of the rockshaft housing is it possible to replace that seal without removing the housing
Ben in KY
02-23-2004 11:51:22
 Re: 444 hydralics question in reply to rex, 02-21-2004 12:26:57
Rex,
How are your rear axle seals ? I have to remove my rear lift box soon to replace my rear axle seals. If yours leak you might want to combine jobs.
Warm in Texas
02-22-2004 14:04:58
My manual says you have to take it apart. Doesn't seem like a huge job, but for one little seal, you may not want the hassle. Looks like a complete gasket and seal set.
Sorry for the bad news, hope it helps though.
Ben in KY
02-22-2004 13:40:11
Rex,
Not ignoring you, but I have hot had that problem so I Don't know whether you have to tear it down to replace the seal or not.
Good luck and let us know how it turns out.
