? about m clutch
TL
02-22-2004 15:01:12
I am putting a 264 from a 400 into a farmall m and wanted to use the 12" clutch and pressure plate.The problem the 400 clutch has a smaller spline on the clutch and will not fit the m.What should I do? Will a super have the 12" and fit on the m spline.Thank you for your help
Dave_Id
02-22-2004 15:57:30
 Re: ? about m clutch in reply to TL, 02-22-2004 15:01:12
One idea is to make a new spline shaft out of the two. The spline of the 400 and the back of the shaft from the M. Or remachine a smaller spline on the M shaft, but that may be too hard for normal machining.
Dave WV
02-22-2004 16:21:10
 Re: Re: ? about m clutch in reply to Dave_Id, 02-22-2004 15:57:30
Use SM clutch plate its a direct fit.
