Carbs???
Anderson
02-22-2004 19:55:14
Does any body have a list of the carbs that fit the farmall's and what their part numbers are? Both zenith and international numbers if possible.
Randy in NE
02-23-2004 04:26:32
 Re: Carbs??? in reply to Anderson, 02-22-2004 19:55:14
The answer to your question is "Yes". If you are looking at all of the various models of tractors with gas engines then there are quite a few of them. If you have a particular model in mind them I am sure that we can help you. I have a copy of Guy Fay's Tractor Data book and a parts CD with all of the part numbers that specifies all of this information but I am not inclinded to spend an hour or more cross-checking every possible combination. As an example the "C" had three different carbs available at the time it was made. No idea if you can still get three all of them today.
