Starter- Pull or Push ?
John in NE
02-23-2004 11:53:28
On my newly aquired 'B',there is a shifter knob on 3/8 all thread going to the starter.To start the tractor,you turn on switch and push on the knob.Not being totally familiar with these,I thought that you pulled on the rod going to the starter.Could the starter gismo be on backwards? Or is it supposed to be a push type affair?I know I need to come up with a new starter rod anyway. John.
BIG JOHN
02-23-2004 18:48:46
 Re: Starter- Pull or Push ? in reply to John in NE, 02-23-2004 11:53:28
A's and B's both had push rod type starter switches. The Super A and the C & Super C had pull type starter switches.
If you turn the switches around they will not make contact with the starter.
I am sure that over the years some of them have been changed for the other and vise-vers's.
Kevin in Michigan
02-23-2004 18:09:43
On my 45 BN the starter is foot operated and matchs three other B's and BN's in the area
RaytA
02-23-2004 16:15:32
I have a B my grandfather drove home new in '48. It has a push rod setup on it. Hope this helps. RayA
TimV
02-23-2004 12:52:41
John: It could be either way. On my folk's '42 "A", the starter is run by a foot lever that you push. On my '45 "A", the starter is run by a hand lever that you pull. Both appear to be original. The important thing is that the actual contact is made on the starter itself, and this switch will be a "normal open" (duh!!) switch that is pushed to make contact and run the starter motor. Once you've located that, the rest of the linkage could vary considerably depending on what someone cobbled up over the last 50 years.
John in NE
02-23-2004 13:04:46
 Re: Re: Starter- Pull or Push ? in reply to TimV, 02-23-2004 12:52:41
Can a person simply turn the contact around on the starter,so that it is a pull instead of a push? The ready rod is starting to tear up some tinwork and needs to be removed.Thanks,John.
TimV
02-23-2004 13:13:52
 Re: Re: Re: Starter- Pull or Push ? in reply to John in NE, 02-23-2004 13:04:46
John: I can't speak first-hand about a "B", as I don't have one handy. However, the engine and transmission are identical to the "A", so it can't be that much different. On an "A", the starter contact works off from a small pin mounted on the starter, which swivels to make contact. Depending on how the linkage was configured, this could be either a "push" or a "pull", but in either case, the contacts still need to press together. This would mean that it would be difficult to make THIS PART of the system be a "pull". However, that's only a small piece of the puzzle--the majority of the issue you're dealing with seems to be the actuator rod, not the contact itself. This could be fabricated to make the action either a push or a pull without too much brainwork. From the sounds of it (being that it's made from allthread) it looks like your system is the result of "field expediency", rather than being the original solution. If that's the case, you could re-route and/or re-fabricate a better solution without having to worry about further compromising the originality of the tractor.
