G S info for Hugh MacKay
Paul in Mich
02-24-2004 18:36:57
Hugh, I E.Mailed the information you asked for as to Groundspeeds for the 66 series. I tried to post it here, but It wouldnt copy and paste. Maybe you can have better luck as there may be more fellows here who would appreciate the same info.
Hugh MacKay
02-24-2004 18:57:35
 Re: G S info for Hugh MacKay in reply to Paul in Mich, 02-24-2004 18:36:57
Paul: Came out fine on the e mail, just like chart in the manual. I had much the same luck as you trying to put 5 speed + TA on here last year. I couldn't get it to work either. Thanks
JB
02-24-2004 19:32:27
 Re: Re: G S info for Hugh MacKay in reply to Hugh MacKay, 02-24-2004 18:57:35
Hi Hugh, Paul, when you attempt to copy/cut and paste from a MSWord or PDF or some other formatted document and it dosen't word. Here is a method that sometimes works:
1)Do the regular highlight and copy or cut.
2)Open a NotePad window and paste into this window. 3)Highlight the text in the NotePad window, then do the copy or cut.
4)Now paste this text into the text box on this web page.
Give it a try and see if it works.
JB
