Farmall 450 engine questions?
Rick in central
02-25-2004 18:07:50
Was wondering did the camshaft have a higher lift lobes then on a 400 or super M? what other changes were there to the tractor?
Dave W V
02-26-2004 04:31:21
 Re: Farmall 450 engine questions? in reply to Rick in central MD, 02-25-2004 18:07:50
Forgot to mention later 400 went to smaller wrist pin dia. on connecting rod and piston that 450 used.
Dave W V
02-25-2004 20:51:01
From factory, other than a change to left hand
threads to hold cam gear on camshaft,made part
way through C281 engine production and a 1/8 larger bore on 450,most 400,450 engines are basicly the same.Early 400 didn't have a dip stick.Some 400 block casting # ended in R1 before
changing to R2 whitch went on to 450.Some advertizements say cam was changed when 400 came out.It would be different than SM,but I have never confirmed it.
randy hall
02-25-2004 20:39:31
m, super m, 400, 450 all had the same valve lift but the 450's cam had a different duration that gives a little more lugging abilitly.
