steering sector removal
ellson
02-26-2004 16:53:04
I'm trying to remove the steering sector. Manual says use a suitable puller? I've tried a wood block and hammer on the nut with no luck Should I use a bigger hammer or is there a suitable puller?
TDK
02-26-2004 22:37:25
 Re: steering sector removal in reply to ellson, 02-26-2004 16:53:04
Make sure you have front wheels about 1-2 inches off ground. The weight of wheels, etc. should help in forcing gear loose. If all else fails, use a little heat and a brass punch. This worked on my "M"!
riverbend
02-26-2004 19:21:45
What tractor are you working on ? Sometimes you need to tighten up a gear puller and give it a good whack with a hammer to pop it loose. But in your case, it is hard to tell.
ellson
02-26-2004 20:19:49
 Re: Re: steering sector removal in reply to riverbend, 02-26-2004 19:21:45
Sorry, I'm working on a Farmall H and can't get the puller on to the sector
