450 Oversize Bearings
Reid from CA
02-26-2004 18:24:07
I need some oversize bearings for a C281 gas engine. The crank needed to be reground and it's 10 under now. There for I need some bearings that are 10 over stock. Any clues on where to find them? I posted here before on this but postings didn't really get me anywhere. Any help is awesome. Thanks.
Earl S.
02-27-2004 19:40:12
 Re: 450 Oversize Bearings in reply to Reid from CA, 02-26-2004 18:24:07
The machine shop should have tried to furnish the brgs. But here you go , Federal Mogul you need 4 ea. 2030 SB .010 rod brgs 1 ea. of 942m .010 main set. (OR) In Clevite you need 4 ea. CB 422P .010 rd brgs. 1 ea.MS 307 .010 main brg set. These are your after market choices one or both made the brgs foe OEM. I hope this helps. Any Good Machine shop should have either brand availabe. Earl In Illinois
Ohio M Puller
02-27-2004 04:45:13
Call Mark Matuck at Ag Repair in Ohio, I know he can get them for you real resonable. Call him at 419 946 6167. Good luck
Karen
02-27-2004 03:35:05
Reid, I wonder why the people that turned the crank didn't have them?? If you email me I believe I know where to get them.
ChadS
02-26-2004 21:25:38
NAPA, IH, will have the .010 bearing kit for the 450. any good engine shop should be able to get them. Just my 2 cents, Chad
