I-140 rear axle removal
Al Schuman
02-27-2004 10:08:30
I have removed the domed cover, I have removed the bolt / washers / spacer- gave a couple of good tugs but the axle is not coming out of the case. Stopping for now looking for whats next. Thanks AL
TDK
02-27-2004 14:23:59
 Re: I-140 rear axle removal in reply to Al Schuman, 02-27-2004 10:08:30
Al, I forgot to tell you to remove bottom pan. Then hold drive gear with pry bar; tap axle in and out until it breaks loose from gear. It will take more than just a pull, use a brass punch or wood block. Looked in the manual this time, this should work.
Al Schuman
02-27-2004 16:47:56
 Re: Re: I-140 rear axle removal in reply to TDK, 02-27-2004 14:23:59
Thank you, DBigDog was over today, good visit. A little extra tapping and knowing the bull gear needed held in position was all I needed, going to finish up latter. Hoping NAPA has the seals. Al
